The Mira 8 Mixer Valve as old as it maybe serves us with no issues used with a Shower pump.
But periodically the Flow valve (On/Off) binds/sticks where you have to try turn both directions to eventually turn off the shower flow.
Whenever this happens, I strip the valve, clean and re-grease with a Rocol silicone grease I have. Once re-assembled all is ok for approx 2 mths before starting to bind/stick again.
What Lubricant should be used on the Brass assembly threads.
thanks
thanks
