hi ive got an old mira 88 shower that leaks through the dials. I cant even prise off the dials so any suggestions as to why and how to sort out?
penfolddmouse said:hi ive got an old mira 88 shower that leaks through the dials. I cant even prise off the dials so any suggestions as to why and how to sort out?
doitall said:penfolddmouse said:hi ive got an old mira 88 shower that leaks through the dials. I cant even prise off the dials so any suggestions as to why and how to sort out?
You don't prise anything off it all comes apart by undoing bits.
If you want the manual send me an email, it's in my profile
christineb said:Thanks for the advice, but I am a plumbing novice!
I have taken the front dial off, took the circlip off the spline, but there is no movement, should I just apply a bit of pressure to get the rest off?
Cant find much info on the power handset thingy, could you point me in the right direction?
Cheers
Doitall I had a Mira 88 and it worked fine on mains pressure so are you sure about what you are saying.doitall said:As for the pump the the pressure should be between 1 and 2 bar max, after which you need to fit an Dereve 7052/4 water pressure governor.
To find a profile click on doitall anywhere you find it in the plumbing index.
pannierstan said:Doitall I had a Mira 88 and it worked fine on mains pressure so are you sure about what you are saying.doitall said:As for the pump the the pressure should be between 1 and 2 bar max, after which you need to fit an Dereve 7052/4 water pressure governor.
My understanding is that they will cope with mains like the Excell or Combiforce.
Stan
