I have a Mira 88 shower valve running off a gravity fed hot water cylinder. The boiler has finally died so we are thinking of replacing it with a combination. WIll this valve work on a combination boiler.
This shower was never designed for mains pressure systems.
I have seen them on combi's etc working ok but have also seen them where they don't and the seals etc have failed.
Thank you for your reply. I thought it might not work. Would the Mira Discovery valve fit in without major pipe alteration and without having to chop tiles off the wall??
