Mira advance start / stop button flashing
15 Jul 2013
Aberdeenshire
My shower which is a Mira advance atl thermostatic 9.0 kw, has been working fine up until now, when switching on the main power switch the shower normally makes 3 beeps , but this time there was nothing - the start stop button was flashing where it is normally a solid blue light. Help needed please
It might not have liked the way you shut it down before.
Switch it off. Leave for 30 seconds or so. Switch back on and leave fro 30 seconds and see if it settles. Otherwise a call to Mira will be needed probably.
You haven't said which version of the Advance you have, but you can find the User/Installation instructions for all models Here
They contain fault finding info, so you are better informed when you contact an electrician or Mira.
Do NOT attempt a repair unless you are COMPETENT.
Water and electricity do not mix.
