Mira cartridge
27 Oct 2008
Berkshire
Hi. Can anyone help with instructions as to how to fit a 930.33 cartridge please? The instructions that came with it are pretty poor. Do I need to drain the tanks or does the fact that the pump is off suffice? Thanks very much.
then you'll have to bung the feeds in the cws tank in loft or drain it.
Was going to turn off the stop cock and run the bath taps until both tanks are empty. Would that work? Anyone know any web site for instructions on how to fit? Thanks
Seco's way saves you wasting the hot or cold water in your tank / cylinder. Your way is fine, just takes longer. Add some form of isolation to the supply to, and feed from, your pump if you can.
Just simply remove the clip on dials and covers from the valve, undo the 4 screws retaining the cartridge, remove the cartridge, smear a little of the supplied grease to the rubber seals on the new cartridge, then gently slide the new cartridge back in place. Refit all the dials and covers in reversal of removal. ;)
Thanks very much for all your help. Will attempt tomorrow! Watch out for new entry in "DIY disasters"!!!
