Mira Discovery ( Hot water only )
5 Sep 2006
I have recently had a Mira Discovery concealed shower fitted into a new Bathroom
It is Fed by a longish run of Hep piping
The Shower is on the ground floor and the Hot water cylinder is upstairs
Problem is that it takes 3 or 4 minutes for any Hot water to get to the shower head.
Then no matter what way you turn the temp control on the Mira you only get scalding hot water
Anyone any ideas
Would a pump help in getting water to the shower quicker
Help
G1nzo said:
The Shower is on the ground floor and the Hot water cylinder is upstairs. Problem is that it takes 3 or 4 minutes for any Hot water to get to the shower head. Then no matter what way you turn the temp control on the Mira you only get scalding hot water.
Anyone any ideas.
In that case you have either a blocked cold supply to the shower, or a faulty shower valve/cartridge. You can service the valve - kits are generally available.
It would if there were no faults and if it was a twin impeller pump and if you connected it in series with the supplies to the shower.
