Mira Discovery Shower.
6 May 2006
Hertfordshire
Hi All.
I have a Mira Discovery Shower that continues to leak from the
Shower head (drips)
I have replaced the O seals as supplied, two on the side and one around the main body.
An help would be apricated.
Thanks in advance
Do you mean the shower head itself or is it leaking from the outlet pipe
If shower head - have you descaled it?
Yes its from the shower head, but it is all clear. it seems to be within the shower valve not
shutting off completely
If you have replaced the seals and haven't damaged them putting them back in , then it's a new cartridge you need
However it's probably cheaper to buy a new shower......
