I have a Mira Excel running gravity fed that has been in some ten years and is no problem but want to have higher pressure spray if possible. I can maybe raise cold tank a further 8 inches so will try that first. I have also acquired a Stuart Turner Showermate 1.4 bar pump to use if necessary. As the Excel can run from 0.5 - 2.0 bar (it has the low pressure cartridge fitted) I rang Mira to ask whether fitting a 1.4 bar pump would be ok. Although very nice they couldn't give me an answer saying that no one had tried this! It might work and might not - which wasn't too helpful from the experts. Anyone tried this and what was the outcome? Many thanks for any help.
