Mira Excel Shower Control
15 Nov 2006
Berkshire
I've got 2 Mira Excel showers in my house. One is working perfectly and the temperature adjustment is fine. The other is losing temperature - even at max setting is now only lukewarm. Used to work perfectly too. Do I need to replace a component? Thanks!
You need a service kit which is about £100 which will get you the complete cartridge or you can get a washer pack and remove the cartridge you have and clean the filters which might be blocked.If that dont work then its the cartridge
New cartridge comes with instructions or you can go to the Mira website.
Its very easy just 4 screws holding it in and then just setting it up for temperature.
Stan
