mira excel thermostat shower leaking on installation help
12 Apr 2005
I have installed a mira power shower no elec as yet. The cold water is at mains pressure, the hot is from a header tank. I cannot turn the isolator from the basin on from the cold supply as the water just comes gushing out of the seal areas. i Have sealed what i thought was the most obvious leak and now the water comes from elsewhere. Is the cold water pressure too high if so what can i do about it?
Can I put a pressure reducing valve on the cold water supply to the shower
The answer is NO! You will have to take the cold to your pump from the cold water storage tank.
