It sounds like the pull switch has failed.
A common reason fir this is becausethe connections were not tightened up enough inside the switch. Over time the connection heats up and will cause the switch to fail. Also the wiring may have melted.
Turn the power off and carefully remove the switch and have a look at the wiring. If its melted and burnt you'll need a new switch of the correct rating.
Also any discoloured wires must to be stripped back to bright copper before reconnecting them.
Yes, he did.It sounds like the pull switch has failed.
Yes, you did.It sounds like the pull switch has failed.
