tte said:hi bud its a mira sprint!! the instructions say to use a comporession joint but just wondered if push fit would do.. cheers
Don't see why you couldn't use a push fit straight connector in place of a compression one (I am assuming that is what you need).
To be pedantic, what was "already said" was that the diameter was too small.denso13 said:As already said the problem is the tail on the shower isn't long enough to get a push fit fully on.
Softus said:To be pedantic, what was "already said" was that the diameter was too small.
