I wonder if anyone can help me sort this problem. I have a Mira Advance shower which is 7 years old. In July last year the shower kept cutting out and eventually was not working at all. I called out a Mira engineer and he replaced the PCB board. It worked fine for several months then started cutting out again, usually when my hair is full of shampoo!! I have had 2 Mira engineers here since the beginning of April, the first one, when the shower would not come on, took the cover off the unit and pressed a button which he said 'purged' it. He ran the shower for several minutes and it never cut out so he left and advised me to keep a record of what happened each day. It seemed ok the first time I used it but then just went back to cutting out. On 23rd April another engineer arrived and despite having constantly been cutting out before he came it ran perfectly while he was here! He 'recommissioned' it which didn't even involve taking the front cover off the unit! Of course it is still cutting out - and I don't really want to go through another engineer coming and doing nothing! Anyone got any ideas what can be causing this? Sometimes there is a burst of water then it cuts out. Sometimes the 'low pressure' light comes on. Sometimes I have to switch it off at the main cord as it won't switch off at the unit. Sometimes it will eventually switch back on but sometimes it refuses to come back on! I am ready to scrap it an buy a new unit, do you think this is necessary?
Thanks in advance!
Agnes
Thanks in advance!
Agnes
