The Mira Excel mixer shower is about 14 years old, white coloured and all the controls and valves etc are behind wall. A few days ago it began to leak and I was told a new cartridge was needed. Professionally repaired by proper plumber etc. First there was no hot water to the shower when it was turned on. The temp control on the front turned but no change. Got the plumber back and he altered the thermostat or some thing. Not present when he did it but my wife was so no knowledge there. This time nothing but hot water. It seems that when the temp control on the front is turned there is no cold water coming in. I've had the whole assembly apart to see what there is. When I did this I could see that in the back behind all the covers there was a blue and red plate which obviously refer to the water feed. When you turn on the shower these plates move to let the water flow. I just wonder if there is an inherent fault with this new cartridge. I also need to find out how to regulate the water temp before my skin totally dissolves with the heat. Can anyone help?????? I'm no plumber so keep it simple.
