Mira Sport 10.8 kw Electric shower
24 Jan 2008
Cardiff
I have a Mira Sport 10.8 kw Electric shower which when turned on, immediatley goes back to standby. i used to be able to stop this behaviour by tapping the on off buttons , but now it just goes to standby as soon as it is turned on
If i turn the thermostat to max heat before turning on, it will power up. i then turn thermostat heat down and all is ok. it continues running till next time i use shower when i have to repeat the procedure
anybody have any suggestions how to cure this ???
Hi PrenticeBoyofDerry
Thanks for your reply.
the overheat and lowflow lights dont come on, the shower just switches straight back to standby (red light)
If i turn thermostat to maximum heat ,the shower will start and i can then turn thermostat to desired heat and all is ok. Till next time shower is used. strange??
