Help please if you can Smile
I have the Mira Sport Max - I have searched this forum etc but cannot find an exactly similar problem or one with a definitive answer and solution...
Had the shower for 2 years. Over this time I have had to increase the temperature dial from half way to 3/4 of the way to achieve the desired temperature. Recently the unit will cut out - i.e. the overheat light will come on and hence water temperature will go cold (allowing the system to cool back down). Then the overheat light will go off and the water temp will increase again for say a minute or so, and so on. The cut out (overheat) seems to occur at quite low temperatures (water still feels tepid) - i.e. I would not have thought that it should only cut out if the water coming out of the shower was quite hot.
Flow seems to be good (pressure does drop off at the higher temperatures but I think it is acceptable). I have checked various items with the multimeter (although far from an expert) i.e. Heating rods seem to have the right resistance. Continuity across the Thermal Cut Out Switch (TCO) until it trips and the overheat light comes on.
Any ideas would be appreciated - Could it be due to limescale in the heating tank? Could it be a faulty TCO that cuts out to early? etc etc
Cheers in advance.
Cheers in advance.
