Mira sport replacement.
11 Jul 2008
Plymouth
I have to replace my mira sport shower. Due to space restriction caused by the shower cubicle door opening, I need a shower with water and electricity fed on the right as you look at it from the front, the pipe needs to go on the bottom very close to the side of the shower. And which doesn't require a straight compression connector. Do you know of one?
If you were happy with the Mira Sport, why don't you just install a new one. They are still available. Or have you changed the enclosure as well?
They have reversed the inlet and outlet, so now the inlet is on the left. The only mira that now has inlet on the right is the mira advanced, which is £399.
