Hi - first post here so hello!
We've got 2 Mira sport showers in the house and have replaced them pretty regularly over the last few years - generally seem to last for 3 years or so before something goes wrong and its often been cheaper to get a new replacement off ebay than call out Mira or replace parts at random. Previously the low pressure lights have come on and there's been no control over temperature.
This time, the shower doesn't show any low flow light, but makes a lot of noise as though the water flow is trying to get through a restricted opening. The flow at the shower head is drastically reduced to not much more than a dribble.
I've tried running it on the cold setting for a few minutes without the hose attached, but the flow rate doesn't change.
Turning the temperature knob doesn't seem to make any difference to flow rate (expected it to be higher flow on a cold setting) or the temperature. The temperature stays cold throughout.
I then tried taking out the filter and found tiny bits of grit/ debris but no obstruction to the flow at all. On re installing the filter and switching the water back on, it worked as normal! Lots of flow, and heat.
Great, but after switching the shower unit off and then back on, we're back to square 1 - noise and low flow at the shower head.
Question is, does this sound like a flow valve problem? I don't want to order the wrong part at £40-£50 if i can help it Are there other checks I should be trying? any help gratefully received!
The heater tank looks like it was made 2011 /09 which makes it 3 years old.
[/img] View media item 82287
