Hi any tips on a remedy to fix a dodgy Mira zest 8.5 kW. Temp does not stay steady when running for a period of time. Problem seems to be intermittent.
Check the simple jobs first.
Check the shower head is not scaled, If so descale overnight.
(Try running shower with head off, see if it cycles hot/cold)
Check inner shower hose is not collapsing. Not always visable easy to fit new hose.
