I have a rental property with a Mira Zest shower which the tenant tells me is not working correctly. He says that the shower is blowing the fuse in the on/off pull switch. He has replaced the fuse and the shower will work for a couple of weeks before it blows again. I'm assuming he is replacing a 13amp fuse. There is a 17th edition board supplying the shower. This is not tripping. Any suggestions as to what might be causing the fuse to blow will be welcomed. Thanks in advance.....Eric
