Hi all, new here and in need of some help.
About to redecorate a family members new flat, and the age of it means it has lead(tested with testing kit) and they are concerned with all the dust about to be created.
Now we can’t replace the woodwork or strip it, so all I was planning on doing is using some festool sanding pads to key it and denib and use the Wagner 3500 and spray everything with whatever they wanted as a finish. Now the debate is, I have 2 Mirka hand sanders, the little grey one and the bigger yellow one, and I also have a wet and dry Henry. They want me to use the Mirkas wet and I’m not sure they can be used wet.
I know I can clean the meshes with water and have some of the JCB meshes and they clean with water, but never considered using these in a wet and dry mode before.
Seems overkill really?..opinions would be good.
