Hi, I hope someone can offer some help !
We recently moved into a house where the kitchen adjoins the garage (the garage goes out further into the back past the outside wall of the kitchen) and the previous owner had moved the washing machine into the garage. The waste from the sink and dishwasher were redirected through the kitchen wall into the garage, where they put some drainage pipes in the garage under the floor to take the water into the main drains (somewhere - i dont know how they are connected but they do drain into the main drainage pipes).
We now want to disconnect all this, and put the sink and dishwasher waste drain back out through the back kitchen wall (you can see where they filled it in) and into the ouside drain........ however, we have dug up the area and cannot find any drain ! It looks like they removed the original drain pipe and presumably blocked the end off.
As we are digging up the area where we think the pipe should be and where we presume it was probaby disconnected, there are what looks like huge blocks of polystyrene.
Is this what is used to block the old pipes off ? Does this mean that we should find a sealed off joint in the pipe somewhere ? Any ideas why all this polystyrene (or whatever it is) is there ?
Any help or guidance is much appreciated...... thanks !
