WANTED--
Advice on how to cut the mitres on Uniclic profile skirting. Tried to follow the very limited and unhelpful instructions without success. You have to use a small wedge shaped packer behind the skirting when cutting in order to get the angle of the cut correct as the skirting is wider at the bottom. The packer is supposed to emulate the angle that that the skirting sits at when fitted to the clips that hold it in place. Once fitted to these clips it is near on impossible to remove the skirting without damaging it.It is supposed to be removable according to Uniclic.
Any advice would be greatly appreciated.
tanto.
tanto.
