Thickness isn't critical on the DW 216mm saws. I use a variety of thickness of blades on my DW777, but all 216mm diameter. To use a smaller diameter blade may require a piece of plywood or MDF to be laid on the bed of the saw to achieve the full cross cut length as you'll probably lose 10 to 15mm off the full crosscut length with the smaller blade
