- Joined
- 20 Oct 2020
- Messages
- 109
- Reaction score
- 3
- Country
Will be replacing all the skirting boards in the house (over the next 100 years....).
Was looking for a compound mitre saw to do the job. The skirting will be around 160mm in height.
How can I tell from the saw if I can put material of this height into it? Which factor do I look for? Is it the blade diameter?
As an example I was looking at a Dewalt DWS773 on a well known global online retailer and the description reads:
Does this mean that I can only get skirting board of 70mm height in the machine? I think ideally I want to mount the skirting board in its normal orientation rather than flat and tilt the machine to the side if that makes sense.
Also what does (from a Makita specification):
The Makita has a blade depth of 260mm.
Additionally, for cutting MDF is there a recommended type of blade and number of teeth?
Opinions welcome. Thanks.
- Maximum depth of cut (saws) 70 mm
- Max. Cross Cut: 95 x 90.5mm
