Hi
I'm building some decking and think I'd be better off buying a power mitre saw.
I'm a bit confused about how wide a saw can cut. If it says it has a max cross cut of 140 then would I be able to cut a piece of 4x1 which is about 10cm wide at 45 degrees left and right? If I cut it at 45degrees then I reckon thats just over 140mm??? so will I need a sliding one?
