Hi all.
Looking for advice regarding mitring and joining stair handrail - mopstick (50mm?).
Customer wants two rails for elderly parent - currently only has handrail halfway up the stairs! Top of stairs has a small landing that you use to do a 90deg turn then a final single step up to the full landing.
Will need to do a number of mitred joints - some changing both in direction and elevation! Most Googled advice says simply mitre and glue - leaving overnight! Haven't got time to do this, too many mitres to do, and concerned joints may simply open up with use.
Has anyone used these zipbolts? http://www.rutlands.co.uk/cabinet-h...s/worktop-connectors/C3601/worktop-connectors
Or these ones? http://www.noawebsites.eu/quaytechuk/11700.html
At top of the stairs, I have to mitre the "inside" handrail around the top newel post - 270degress - basically round three faces of the post. Previously done this by using a 50mm hole cutter to cut one end - drill through and screw, then sand off all the excess. Joint looked a bit like joining hollow pipework - if you know what I mean? However, on this one have to take into account the rail is also rising!
Wonder if clamps will solve all?
Cheers,
Neil
Cheers,
Neil
