Mix Polyplumb and speedfit?
19 Oct 2008
I need to add another radiator. I have all the bits to do the job in Polyplumb. Thought I had some offcuts in 10mm to pipe it, but found out I must have used the last on anther DIY job.
Question is.....can I insert 10 mm speedfit pipe into a 10mm polyplumb T piece and exect a good fit?
It seems I can only get 10mm Polyplumb on a 50 metre role which is way too much and expensive.
Cheers
madgolf :rolleyes:
Yes as long as you use the correct pipe inserts the outside diameter of the pipe will be the same.
