- Joined
- 6 Nov 2003
- Messages
- 326
- Reaction score
- 4
- Country
Hi
At present I have an electric 8.4Kw shower. i'm not happy with the flow rate at all. I am getting a combi boiler fitted to replace the back boiler which heats a hot water tank at present. The combi boiler will be a worcster bosch 28 condenser, I think this is a good one.
The cabling to the shower is 6mm so I don't think I can go much higher with the electric shower rating. Another option I think is to get a mixer shower running of the combi direct with mains cold water feed. Will this actually be better than the electric shower though? I ask this because it means I will have to pull tiles off and run pipes in etc so not a simple task and so only want to do it if it will be better than the present electric unit!
I know the only sure way would be to get a pump fitted but I don't want to have water tanks.
The taps are on the opposite end to where the shower is and so I cannot use the tap/shower units.
The cold water flow rate is approx 18l/min.
So will an unpumped mixer be better then an electric shower? I'm a bit confused because I went to B&Q and looked at the strength ratings, the mixers have different strength ratings rnaging from 6-12, but I thought the strength would be dependant on the water pressure feed to the shower??? How can they have a strength rating when they dont know what the flow rate to the mixer is?
Sorry for the long and propably incomprehensable question?
