Mixer shower after electric
16 Jan 2011
Hi All,
I've just moved house and in a lovely bathroom I have a miserable 8.5Kw Triton T80, my previous residence had a super Aqualisa mixer, which was fantastic.
The triton is fed by pvc pipe from tee connection to the bath cold water pipe. The house has a gravity fed system & convention boiler.
I want to change the shower to something more powerful. I really don't want to upset the bathroom decor too much so I was thinking about fitting something like the powered Mira Platinum rear fed shower, I was hoping to use the pipe work from the Triton and connect at the same rear feed at tile level. I was wondering if I could put the digital mixer valve under the bath and run the hot & cold feeds from the bath pipework to the inlets and the use the 'Triton feed' pipe for the output. I'm assuming that the pressure from the cold water is OK as it was used to feed the Triton.
Would this work or do I need to be aware of anything.
Any feedback is welcome.
Tony
Mira Platinum will require gravity feed from your hot/cold.
your triton T80 willbe mains pressure pipework.
so your hot willbe ok your cold is mains not gravity.
Thanks for the reply.
Would it be possible to put a pressure reducer on the cold water feed to simulate the gravity feed?
Tony
