Mixer shower Help - Name and model?plus mixer not hot enough
pjt
20 Jan 2010
Hi Guys, need some help once again,
I have a mixer shower which is not giving off enough hot water when in shower, heres what happens,
turn shower on and fully over to hot
shower is only warm
So i spoke to British Gas Engineer the other day (he was fixing my faulty boiler (PCB) (not related to Shower problem), he says it either
1. There is too much Cold water coming through
2. mixer shower is faulty
So i go under bath and reduce the CW to a trickle and Hot water to on Full, water is still just warm.
My questions are -
1. Is their anything else can be done to fix this?
2. I cannot find anything on my mixer shower telling me a make or model. Except for the letter "T" (this is in Blue and the "T" is written in Dots.
What make is my mixer shower?, any help would be great
See Image below
its not hot as boiling but its probably the same temp as what comes out of the shower
then i wouldn't put it down to a shower fault more of whats supplying the shower.
if the pipes only warm then the shower can only be as hot as the water to it.
thats an exposed ctv trevi mixer
if its only a manual not thermostatic then more chance of being a supply fault.
Cheers for your help,
I have just checked again, and the temp seems to be a bit up and down, for a few minutes it will be hot (not boiling) , then bit cooler.
The hot pipe on the shower runs of the main pipe to the bath, i just checked the hot tap on the bath and its boiling, so im thinking its obvoiusly something from there to the shower.
Just a question, theres a gate valve on the HW pipe going to the shower, when i open the hot pipe valve, the more i open it, the pipe make the gushing noise the more i open it, (like more water is getting through noise) this noise continues, is this ok or am i best not opening the hot water valve that far
(hope that makes sense)
Cheers
Phil
sorry, no it isnt the same as that one
any isolation valves to the shower want to be fully open.
as for the gushing noise is it only while the showers running ?
yeah the gushing noise is just whilst the shower is on, just really need to know if its ok having the open fully, will give it a try fully open on hot and limit the cold coming through and see if it makes any difference
Cheers
Phil
These shower valves have a temperature stop which is adjustable between 40 -48 deg.
It need adjusting up a bit.
i think the hot and cold have been crossed during intulation
