Hi peeps is there a standard distance between the hot and cold pipes on a direct mixer shower thats set in a wall as im putting the pipework in but havent got the shower yet and dont want to board the wall then realise the pipes are not far enough apart!!
There isn't a standard pipe size as such but the majority of mixing valves have the Hot and Cold pipes 150mm apart. I think Mira showers are 147mm and Bristan are 150mm.
