Just fitted a new basin with a Grohe mixer tap. The tap has 2 flexis pre-installed which I have connected to hot and other to cold.
Our system is a Worcester 28i Junior boiler, cold tank still present in loft feeding all cold taps in Bungalow (except Kitchen). No hot water tank. Hot water pressure is higher than the cold, due to tank on loft? Can this be bypassed?
Anyway, after plumbing the new basin, I noticed the cold pipe behind the basin was getting warm. Switched mixer to cold and after 30 seconds it gets cold again. Ran it at part hot and part cold and same again, cold pipe gets warm.
Do I just need to fit non return valves? On both or Cold feed to basin only? I have isolation valves 10 inches off the floor, so non return valves between these and basin?
I will also be fitting a thermostatic shower mixer so would I put non return valves on the shower feeds also?
