mixer tap problem
21 Nov 2008
hi i have a mixer tap and the hot water keeps dripping and making a noise but the colds is fine what is the problem ?
where you turn the tap on will have a cartridge/tap washer that is letting by.
sounds like you have a cartridge mixer.
you'll need to isolate and remove the cartridge.
The tap has a lever up for cold and down for hot, do i pull the lever off to get to the cartridge?
there may be a concealed screw or pin, all makes differ so if you know the manufacturer you may be able to download a tech sheet to help.
