The tap lever(the part you turn)was moving but the tap wouldnt flow. I took it to bits and it had a plastic inner body which revoves within a plastc outer body the inner body has splined end which fits in to the tap lever this spline is worn and the reason for the problem Is it possible to obtain these parts and where would be the place to go Thanks for any help
Mikel
Mikel
