Further to one of my recent posts discussing manifolds and distributing the how water around the house:-
Our existing 3 bedroom house has 10mm microbore throughout for central heating. This is now over 17 years old and still works 100%.
We are building a large extension to the side of the house which will require an additional 4-5 radiators (Inc en-suite).
We are having a new boiler fitted in the extension to supply the whole house. This will have a 22mm output pipe which will join the existing flow and return pipes.
Should I use 10mm microbore in the extension or 15mm instead?
Bear in mind the extension will get the hot water first as it's closer to the boiler, it will also be far more insulated than the existing house so will need less heat to bring it up to temperature.
Looking around at copper and connecting prices there doesn't seem to be much in it between them.
Microbore would be easier to run as I can go straight through the joists and there will be no joins under floorboards to leak. (Although the furthest radiator on the 1st floor will be 10m away from the 22mm pipe)
Thoughts/Opinions?
Thoughts/Opinions?
