I have a non-standard velux window 94*118 (P06) - Is it possible to mix two flashing kits to get the correct height and width, as I am finding it diffiucult to find the correct size.
My plan was to by one kit which had a width of 94 and one kit which had height of 118, but if you are saying that velux would be able provide this as one kit then would this be a cheaper option ie. around £80?
My window is a P06 which is not usual UK stock.
Also out of interest and back to original question, can different kits be mixed to create an ad-hoc size?
Absolutely no reason why you can not mix the two flashing kits , provided they are the same code kits... eg: two edz.. Should your roof be slated then you'll just need 1 EDL..
However you could simply by a kit for a P10 window and trim the side flashings to length.. there by buying only 1 kit. easy!
