Mk Grid Switches...
22 Sep 2012
Manchester
Can anyone confirm,
need to put in a 2 gang grid switch, can the white plates and grid frames attack to regular metal back boxes, or do they need to go on the grid system back boxes?
cheers
metal and plasterboard boxes will work just the same.
Just ensure they are the deeper ones, 35mm ( i think).
Yep, don't try flushing one of those in!
MK do do flush mounting boxes, but standard 1 gang and 2 gang boxes can be used. As you up to 6 modules and above, you would need to use the MK flush back boxes, although other makes are suitable too.
Thanks for the replys... Will sink a normal teal back box... See how it goes.., only a single anyway.
Thanks.
