MK Logic Plus Grid Dimmer Modules with LED fittings
8 Oct 2005
Does anyone know whether MK manufacture a dimmer module that will fit into a grid that is suitable for LED downlighters? Total load will be 4 fittings @ 7w on each. So the max load presented to the dimmer will be 28w.
MK's site say the K4500 & K4501 modules are suitable for wire wound and 'good quality' electronic transformers or with main voltage halogen fittings incorporating GU10 base fittings, but they are also subject to 40w minimum loads.
Aurora M7 downlights are being fitted, and Aurora produce their own dimmer module, an AU-DSP400X, but I don't know whether that will fit in with an MK LP Grid, or sits on its own proprietary faceplate, which wouldn't match everything else.
Any help welcome!
