Modena 80 E fires up the goes out after 1 min
1 Jan 2007
Kent
hi all could someone help me, my modena 80e boiler fires up on hot water then goes of after a min, but my central heating only comes on now and then, thanks nick
now i wont work at all, i have gas and the spark, i thought it was the pressure i've done what the manual says may need to get the plumber round? :rolleyes:
If you have a gas supply and its sparking then that would usually be a failed gas valve.
However, that is not that common on your model at this time of year and could also be the PCB ( or just possibly an o/h stat? Anyone? ).
You may need a boiler engineer.
Tony
I think you should try a little harder to find someone local who will come to you in the next 48 hours.
I am going to a repair this afternoon but have nothing in particular to repair tomorrow apart from three dirty systems to clear.
Tony
how much would i be looking at to get you to have a look for me, have some spares on the way as well,
£5k . agile did say get some one local to YOU, which implies he is in the other end of the country
Oh, Agile if you take the job at £5k, £1k for me commision ;)
ha ha, i'm off out if you can get someone out to me just let me know on (email address removed) will love to pay 5k? yeh right, will make sure your electy bill goes up??
_____________________________
lynda, moderator
Please note forum rule 7
I had the same problem..and what cured it..was ...replacing the venturi ( which i broke by accident) in the fan housing...
this corrected all the problems I had been experiencing..firing up for a min then going off..not firing up at all..etc
hope this helps
