This question is two-fold.
I am submitting plans for a two storey extension above my garage (actually knocking the garage down and rebuilding two storeys in its place), but have asked the architect to specify attic trusses and the correct floor joists above the first floor (ie in the loft) IN CASE I might want to do a loft conversion at a later date. I am also laying out the first floor rooms (and creating the ceiling apertures, though plasterboarded and framed over) so I can easily add a staircase to the attic room should I decide to use that space at a later date. This staircase would be located in place of a small bedroom on the first floor.
Note, I am NOT installing a third floor at this time, though the architect has put the text "attic trusses in anticipation of future conversion" and "velux windows in anticipation of future conversion" on the plans (which I'd like him to take out)
So once my extension is complete, I will have a four bedroom house, where the fourth bedroom is quite small.
At a later date, if I decide to use the loft space / third floor, I will put a staircase where the fourth bedroom is, and create a much larger bedroom in the attic space. The house will still be "four bedrooms", only the fourth bedroom will now be much, much larger - could even be a master bedroom.
Will I need to re-apply for permission if I decide to put in the staircase, though no structural work will be needed at that time (there will already be a couple of velux windows in the roof)?
On the other hand, if I do the loft conversion and staircase as part of the plans submitted this time around, but just leave that fourth bedroom as-is, with the stairwell boarded over, then is that a problem as far as completion certs go?
My second question relates to the position of non-load-bearing internal walls / doors etc and deviating from the agreed plan during the build.
If I want to make an aperture wider, for example, or move a door to a bedroom, change the layout of a bathroom etc, can I do that during the build, after the plans are approved?
Can I carry on making changes to the existing part of my house (which individually wouldn't need permission) though the existing layout is detailed on the extension plans?
thanks
Guy
thanks
Guy
