Modifying radiator pipework
29 Jun 2006
Hello,
I'm fitting a new radiator which is slightly narrower than the existing one. I need to modify the pipework above ground slightly. If I drain the system will I be able to solder some new fittings on, even though there may still be some remnants of water in the pipework.
Thanks.
Aha! I've done some research and worked out a solution. Going to fit a service valve :)
