Hello forum, could you please advise on the following,
I have a Micromat HS 31kw condensing boiler((bought from eco hometec Doncaster, (who have gone into demise)about 10 years ago when I installed underfloor heating in my house))
and it is cycling between hot / cold every approx 2/3 mins.(It gets up to set temp 60* then falls back to 50*)
The boiler has a modulating fan, burner and pump and I suspect one or more of these are not functioning properly but how do I check this out?
I have a grunfos 15/60 pump external to the boiler but controlled by the boiler operation and there is also a further 15/60 pump at the underfloor manifold that is controlled by the honeywell heating control box and I have adjusted the speed of these but with no change to the cycle time
If anybody can point me in the Direction of finding the source of this problem I would appreciate that
Paul C
Paul C
