Dear all
I'm hoping someone out there might be able to help me. I've done as much reading around as I can (as well as experiment with different set ups) and have not been able to find a solution on my own.
Apologies if this comes across a bit novice-like. I've tried to explain it as best I can.
IN BRIEF:
I've set up my aerial (via a loftbox) so that I have an aerial inputs in nearly every room of the house.
But a modulator I'm using (for a small CCTV unit) is ruining the signal I send round to the rest of my house. The CCTV is black & white and has no sound and I'm quite happy with that.
MORE DETAIL:
Here's how the system I've installed works:
1. I have a good aerail on the roof (approx 1 year old) which puts out a good, strong, signal.
2. The 'main'/'primary' aerial lead runs from the roof to the ground floor.
3. At this point, on the ground floor, I connect in the CCTV unit. This has a scart, so I have to modulate the signal back so that I can shoot it back up to the loft.
4. Once back in the loft, I connect this lead to my Loftbox.
5. At that point, the loftbox sends aerial leads back down to the various rooms in the house. This means that each room also sees the CCTV picture. A bit grainy but great to have.
PROBLEM:
The problem is that, once I attach the CCTV modulator, the signal becomes much worse. This was bad enough on analogue TV. But now that I've got Freeview, I'm missing some of the main channels (itv1, Ch4).
If I remove the CCTV/modulator unit from the system, the picture on all the rooms being fed is crystal clear again (both on analogue and freeview).
The modulator I'm using is a £40 jobbie from Maplins (I did try using another one too, but that made no difference).
Does anyone have any ideas on:
1. How I can improve the signal (and stop the modulator doing this)?
2. Recommend any product that might help? I don't mind blowing the budget on a much better modulator - but from what I've read, they all do pretty much the same thing, don't they? If you can recommend one, I'd be interested to hear.
Sorry if this is a bit rambling!
Any help would be really appreciated.
MODERATOR - apologies if I've put this in the wrong forum. Please feel free to move it.
IN BRIEF:
MORE DETAIL:
PROBLEM:
