Which one would be better? Moisture resistant or foil backed for the ceiling in the room below the loft?
Originally I was supposed to insulate in between joists with insulation, then thermal laminate, then foil backed plasterboard. Instead, the insulation in between the joists was moved in between the rafters followed by the thermal laminate.
That's good enough for the loft but I am not sure if I still need foil backed plasterboard for the ceiling below or will the moisture resistant one be good too?
In fact, what is the difference? Will I have any problems using a wrong plasterboard?
Many thanks.
Many thanks.
