A recent extension on the back of my house is having some issues with moisture weeping into the building at floor level between two DPC membranes in the internal wall.
Whilst we're still investigating just what the cause can be with the builder, who I must say was superb throughout the build, I thought I'd raise my concerns here and hopefully get some ideas from the clearly experienced people on this forum.
We wanted to be able to back-fill the external side-wall with earth, to maintain an external floor-height for some paving stones, so the builder came up with the idea of raising a DPC up the cavity to keep moisture out if any were to ingress through the external brickwork. He said that the method used was standard practice and was something he'd done before without any issues many times.
I took photographs during the build for my own historical purposes, and I've drawn a picture here showing how he's carried out the work in this area :-
http://i.imgur.com/VqVMC.jpg
There has been a steady trickle of moisture along the area shown on the picture, definitely coming between the two membranes that can clearly be seen from inside the building. This has been ongoing for some time now. I first thought it might have just been water that had ingressed during the build, but it's shown no sign of stopping over the past two months and I'm not getting a bit concerned as to just what's causing it, and more importantly what we can do to sort it out.
After talking to the builder I raised my concerns as to why a 'trough' of DPC was made that crossed the cavity, where any moisture at all that was ever either to build up due to condensation, or get ingressed at all at any point due to pure water-ingress would now certainly be 'led' into the building by what I can only describe as a trough of DPC.
I asked why the cavity DPC was not turned the other way, so any moisture was led 'out' of the building and not 'in', or why the cavity DPC was not cut along the bottom section, so as not to bridge the cavity at all, and any moisture would simply drop into the cavity bottom. I'm not sure I got a good answer to those questions.
Has anyone got any views on what's gone on here, and the possibilities for the moisture ingress ? I'm beginning to think it's purely a condensation issue now to be honest, rather than any sort of internal leak above the DPC being 'caught' by the trough, as the moisture simply isn't enough given the amount of rain we've had lately. It seems to be more of a steady trickle rather than a 'stop/start' deluge.
I'd also like to hear of any possible solutions that I could suggest. I'm loathe to do anything from the inside of the building, purely due to cosmetic issues now we've decorated, but I could probably get into the cavity from the outside if required.
Could any possible solution, if it is condensation-based, be just getting into the cavity and cutting right across the bottom section of the DPC that's bridging the cavity ? I'm assuming any moisture would then drop straight down the external wall and into the cavity, rather than being 'led' into the building, but if the cavity-insulation is getting damp due to any condensation, could that in itself be an issue with damp crossing the insulation onto the internal wall, above the internal-wall DPC ?
Apologies for the long post, but I hope I've explained the situation, and I'd be very grateful indeed for any help or advice.
Cheers,
Isitwinteralready
Cheers,
Isitwinteralready
