As some of you know, Ford, in their wisdom, decided to rivet the bottom ball joint to the lower arm, instead of using nuts and bolts. The lower arm has a horizontal fixing at the back end so it can be hard to bend the lower arm down far enough to get the ball joint out of the hole in the steering knuckle. Bend it too far, and it can knacker the lower arm bush.This is the problem I am currently wrestling with. A local garage tells me that their method is to grind through the ball joint. This allows the strut to be moved enough to give clearance to grind off the rivet heads and punch the remains out. The new ball joint is then attached with nuts and bolts.
My questions to you gentlemen is: Have you ever done this job and is there another way of doing it. Thanks.
