I'd thought that a kitchen monobloc mixertap, by law, must be duel-stream. But one plumber told me that for a monoblock kitchen mixer
tap fed from a combi I need a double check valve in the hot pipe because of the pressure differential between cold and hot. He also said that
if a washer-dryer is tee'd off of the cold pipe only, I only need a single check valve (+service valve) between tee and washer-dryer for that.
Another plumber, however, said I need no valve in the hot pipe, and a double check valve in the cold pipe, in front of the tee.
Does anyone know the right answer to this?
wetfeet
wetfeet
