Hoping someone could advise me on the best way of bending the copper tail pipes that come with Monobloc taps.
The reason I ask is that I need to do bend these both slightly outward and then downward again for them to link up to the hot and cold 15mm supply pipes.
Is it possible to bend these by hand once they have been connected to the taps or should it be done without them being connected if so what is the best technique to ensure they will link up to the supply pipes. I was hoping to avoid using flexi tails.
I do have a hand pipe bending tool that I have used for some other work but these pipes are a bit too small to fit correctly under the former.
Any pointers would be appreciated.
Barrie
Barrie
