Some weeks ago the H.W side of my monobloc kitchen tap started to drip. After putting up with it for a month or so I decided to try and inspect and if necessary replace the faulty ceramic cartridge. Struggle as I might, I could not budge what I assume to be the cartridge which is behind the H.W.knob.
I therefore removed the tap, put it carefully in a vice to hold it, and tried again to turn the hexagonal nut which I assume is on the end of the cartridge. Once again the nut/cartridge would not turn. I ended up buying a new monobloc tap of similar style to the original. The new tap is of a make called Swirl. The original one, by the way, is only about four years old.
Before installing the new tap I thought I would make sure the cartridges could be removed for future reference. Once again, however, the cartridges would not budge.
Could anyone please explain why the cartridges seem to be unmoveable. I do not fancy having to buy and fit a new monobloc each time it starts to drip.
Many thanks.
Many thanks.
